Im back with some mixed info on the bike
Soo compression tester arrived today soo got the bike started with ez start but died within 2m i checked the fuel filter and all fuel was drained from it. So at this point it looks like a fuel issue cuz no matter how much i crank fuel filter is same, so i decided to take of the suction pipe on put my finger on it, it was sucking air or something, a bit on the low side but i wouldnt know how strong the suction is suppose to be, i then took off the tank, and hardly any fuel was dripping from it. I then blowed into filter and could hear clear passageway as in i could hear air go around past filter, i then sprayed ez start in intake again and now starts up like everytime without tank with ez start, now gonna get new fuel lines (seen some on hyoridershop), already have a spare fuel filter. Now how do i go with cleaning the tank properly and clear any blockage?. Also one of my spark plugs the rear one center of it is white, front is tiny bit white. Now the other part, i wasnt able to keep engine running for 10m but ran for about 2 or less at 3k rpm engine was warm but not hot, i then removed both spark plugs, tank is off aswell and cranked on rear i got 75psi and front 65psi throttle on full, now the tester i got is a cheap one from ebay and the thread isnt long as in the thread length is only a quarter long so sits higher then a spark plug. So i don’t know if the reading is correct and the last thing i want is less compression, as the cost would be a lot and i dont think it would be worth it as i bought this bike with my fist paycheck at this job i got around the time so i could use it as a fun commuter bike, it has 23kmiles which is not that bad but it is what it is, is there any other way of testing this? Or confirming, as remember the bike did run at idle and would start up first time not long ago and would rev up nicely if i held the throttle for a couple of secs, and even now with ez start it starts up fine. Compression issue is what i feared after buying this bike really hoping it aint..
