Shiby
Sprayed carb cleaner on intake pipes and had a look around and nothing, vacuum seems fine over there, Opened the carb up, sprayed air into every hole, removed jets sprayed air in there, everything seems clear, closed carb up and tried starting her, wouldnt start sprayed ez start in intake and she started and kept running, randomly started reving up high to about 7k then to 9k then back down and then again, i let the bike do its thing for a bit as long as it leeps goong back down and not hanging at a high rpm eventually it started going back to 2k but then would rev back up to 3-4k by itself, after waiting for a bit it shut off, wouldnt start unless i used ez start and after getting the engine running again it would only idle at 3k rpm and would die at any under just like before, still waiting on the compression tester to arrive. As the bike was randomly reving up it drank decent amount of fuel the fuel filter usually full of fuel as i look at it, now only quarter full even when bike running.
