Shiby
  • Topics: 1
  • Country: United kingdom
  • Bike Model: GT125R
Hi a update on the 06 gt125r
After getting spark i gave her some fuel and cranked, only ran when full choke and full throttle and like 10s of cranking, once idle for a bit then would rev up perfectly but would cut out after some revs when trying to idle again. Decided to clean up carb, once carb was clean reinstalled and tried cranking wouldnt start up… the fuel mixture screw was tampered with before so i decided to give it 2.5 out and cranked it, the bike started first try without use of throttle and was idle good, but when id try give it revs it wouldnt budge unless i held the throttle open for about 5s then it would rev up and rev up perfectly and then idle, but after 2m it would cut out and not start again it would try but wouldnt be able to, i checked the battery and charged, now after multiple attempts apparently this bike will only start at 13.2v and it always cuts out at 13.07v like always at that number, at first i was thinking it may be the carb but after searching online apparently the battery could also cause issues like bike not reving up (mine does rev up but needs throttle on for a couple secs). As the bike only starts at 13.2v and not at 13.07v guessing the battery is at fault and needs replacing?, will buy YUASA YTX 14BS battery as a replacement.
