Every Hyosung bike i’ve had to fix regarding suspension had leaked oil,  it would be a nice surprise if they started using GAS  instead of OIL.   But their site still mentions oil use even for Cars / Trucks
Shock Absorbers
Please do the tutorial , that would be a great knowledge base for the forum!
The reason for using a shaft & nut with a U bracket is probably likely that  KYB uses that shock on a different bike other than Hyosung , so it may not be as exclusive as we think on the updated part,  just the U part made for hyosung to fit our bikes.  I have a suspicion Suzuki may still be using KYB shocks   (as they did since the early SV & GSX days but different mountings & heights due to swingarm clearance , ours has a narrower clearance!)    – the 07′ shock was overall better built but exclusively for 250R , i’ve not seen yet another bike use that shock.
Don’t change anything on the current shock right now , but  keep an eye on the  U-bracket , and improve it when the time comes.   Spring position will not matter as long the big 2x nuts squeeze the spring more for a stiffer ride or loosen for a bouncier ride.
I’ve leaved over the years , that a slightly stiffer setting is best on these 180 kg bikes.  I never felt comfortable riding even on the loose setting, the handling was just risky in the rainy roads.
