LaserBeam
Jake C i adjusted mny idle speed to between 1100 to 1200 RPM at idlle when the engine is WARM. Closer to 1200RPM will probably suit most. If i put the idle to 1500 RPM it makes it hard to shift the gears into NEUTRAL. Lower revs at idle fixed that and it uses less fuel sitting at the traffic lights.
Your bike may just need more air into the carbs but i would replace the 2x FLOAT- VALVES and give the carbies a good spray with CARB-R-CLEAN by CRC or similar product.
