LaserBeam
  • Topics: 14
Thanks Marcel. I didn’t think any 250 shocks had adjustable damping but i was hoping.
This shock is NITROGEN gas filled. It is not oil.
This KR shock has a Made In China sticker on the Yellow Barcode Label. I bet its not Japanese.
Why is the spring upside down, you reckon? The tighter winds of spring are at bottom of shock where as the originals are the opposite?
Should i unnscrew the preload tensioner and pull the spring off & turn it around????
Or leave it as it is????
The U-Shaped bracket does look weak. The SHAFT that the U-Shape bracket is bolted too also looks  weak compared to the stock shock.
-----LaserBeam---->
