Apr 8, 2025 at 6:12 PM
#19277
Thanks Marcel
I’ll try and clean it up and smack a security torx in. Hopefully she will turn. I’m slightly encouraged because the hex nut turns.
I also didn’t think of the idea of welding the torx bit into the bolt so I may try that if all else fails.
Either way she will.be off the road as she is out of MOT.
She needs a new horn and number plate light along with the exhaust fixings to pass.
On a positive note I did a compression test if her the other week and had an evening 160 psi on each cylinder so the engines good at least 🤣
