Shiby
  • Topics: 1
  • Country: United kingdom
  • Bike Model: GT125R
Im back
Soo about the ignition coil test, do you want me to test primary coil (power pin and bolt hole)? If so the reading is 0.2ish, the termials do need a clean tho as they are a bit rusty.
As for the harness it does not exist 😭
The bikes wires are all taped up by previous owner, not sure if thats a good thing or a bad thing as they are taped up good so i doubt water will get in em. I believe the bike was left outside for some time in winter by previous owner and there are signs of rust in some places and some connectors are a bit rusty, the fuel tank sensor has rusted out completely no reading from it (bike shows full fuel on gauge). This bike is a 06 with high mileage, i dont know the exact mileage as it has been tampered with in the past, at one point it had 30k then straight to 0 then to 20k now at 23k on the odo, so it has been used alot and by age probably falling apart but should be fine, hopefully.
There was a video uploaded to YouTube, someone selling my exact bike 13 years ago, which i found interesting as apparently it used to have a alarm system installed.
Still has the fuel tank dent
And fairings are in ruff shape without paint.
Still waiting for the stator unit should arrive by the end of the month.
