Yes it is. So its nothing to be worried about. Thank you. One more thing i just noticed maybe its a common issue. The rear blinkers dont work but the front one does? Could it be a fuse? Or should i look for something else that is causing that problem.
Have a look at the connectors and verify there is pulsing 12v going there or replace the bulbs inside the OEM indicators    (assumed OEM , as you did not say if they are LED aftermarkets)
Indicators use a 3Pin Relay.
