You could monitor the A/F  ratio on the exhaust and also use some kind of heat gun to measure cylinder temperature so you know which one is still cold ? as you said it stalls in 15mins of working ?   =
Measure that temp sensor on the front cylinder cold and hot values vs the manual figures.
Removing the flywheel does not require a full dismantle of the engine.   Just the flywheel stator cover off,  then extract the flywheel out , that’s it.   You should be able to see if the sprag system is worn down  (since it is 26,000 km , so it could be worth a look!)
