Jan 9, 2025 at 4:28 PM
#18452
Hmmm,
If it helps, here is a few spare parts from our ebay
This one is the last one we got and likely may or may not work but i could not test out of the donor bike as engine was removed
https://www.ebay.co.uk/itm/254811047849
If you need just the plate? (Yellow plate goes to the frame, here it is)
On your airbox = you can fit a dead ISCV to block the airbox hole and its 2 nipples under it.
If your frame does not have the welding spot to attach the metal shell , then keep using the airbox for your ISCV unit when the issue is resolved.
The metal shell will just be for testing ?
Good luck!
