Regulator = On this site, look at the shop product pictures, you will see how big it is but owners managed to fit it there.  (Bigger is better)
It is the 1st thing i would replace yes,   other electrics should be fine.  They can be tested later.
As for wires, it’s hard to see properly , maybe I will have better answers as i study more pictures of your harness and its plugs , where they are connecting to etc and proper look of wire colours so i don’t make wrong assumptions.
The fuel tank level sensor must not be connected until you see the plug that has 1x Yellow  AND 1x black on its white connector.
If there is suspicion on the fuel pump  and the owner did anyhing sketchy to the harness to block the pump etc…. (ie. direct feed from tap straight to carb)
Then i would advise later down the line it is better to have a vacuum pump fitted to the bike.   We will get there slowly as I can see a lot to do there.    Send us a message on ebay if the center stand is needed and I may post everything at once
If the pump is not working,  i would not get a new one,   nothing good about relying on electric pumps for carb bikes as there will be clones made in China.    All my own carb machines have mikuni vacuum pumps , they never bothered me for years on end.
