adamN
πŸ‘€ Member
πŸ–Š Topic Author
  • Topics: 2
Hi, thanks for answer πŸ™‚ right so I’ll already buy new hoses so I will replace them as those really looks outdated, in terms of carbs it seems that they are pretty much new even those hoses seems fresh, that fuel pump was already connected (yellow cable sleeve coming from back of it) to pit near battery, I will check it out properly and send a picture of it but I assume that will be alright, I also already get new fuel filter as this one got some bits there and it wasn’t look good so that will be all replaced, I was just not sure about connection of hoses coming to that fuel pump as there is not stated with ⬆️⬇️and I don’t wanna drown her, there is just last two bits to connect which one got that closed circuit (end with red wire you can see it on photo) and black and yellow coming around that fuel pump and that’s I assume goes to tank as fuel counter. What I think that previous owner either strip her down by that parts whats been missing or start making it new and don’t finish it, when I put air system together (many thanks for it what we missing is just that F***** air box πŸ˜€ ) I just awaiting new handlebars with levers and grips so I can make brake bleeding and then she could be ready for test ride πŸ€™
