Dec 12, 2024 at 1:37 AM
#17958
Also, clear pipe , drain bowl loosened , look at the float bowl has _______ lines like that ______ , thats fuel height , you can have the clear hose against it to see if the fuel level is the same or carb is overflow on one pot or the other.
The lines I have marked in blue is what you were talking about in the above quote?
