Dec 5, 2024 at 7:53 PM
#17889
Just make sure you looik at your flywheel starting system cause if a part is damaged , it could flow loose inside motor and damage something else like a loose tooth! This will save you damaging another starter motor.
If we sort the crank first , then starter motor , and now we can move on to engine and electrics and fuel system using my comments from the 1st reply i gave you above ^
So follow it over & over again. If you finish my list correctly, you will learn something new to fix or make good progress.
