Hey,
Good pic but i couldn’t see the rest of your bike setup where did the other pipes go, what happend to the other throttle body?
This is the setup for your 2008 bike,
Also take note , the rest of the pipe set up that follows the AIS (egr / air valve system) device
The sign of high revs could also mean the air filter has rattled loose ? (Inspect the filter bolts) – When taking out throttle bodies, inspect their o-rings like image above.
I know for a fact this also happens on carby bikes with leaky o-rings – They rev high, the rpm needle takes a while to return down to idle.
