Dan
  • Topics: 1
Hi I used your guide to clean my jets as the bike I have purchased had problems with idle and sluggish power. I presumed it was due to dirty carb. I took it apart found lot of dirt inside the float bowl and clogged jets. Cleaned it up a little bit, put everything together and bike does not start. I can see bit of leakage on the rubber intake , as seen on the pic below, but it is all correctly inserted into the rubber and the clamps are tigthened. What do I do to stop the leakage ? Is it the reason for the bike not starting?
dav
