Nov 16, 2024 at 6:23 PM
#15538
Look for my reply with a picture here
This is the correct way because the manual has errors with carb information,
Adjustments can be done incrementally on the float tangs
Also, clear pipe , drain bowl loosened , look at the float bowl has _______ lines like that ______ , thats fuel height , you can have the clear hose against it to see if the fuel level is the same or carb is overflow on one pot or the other.
