Jo
πŸ‘€ Member
πŸ–Š Topic Author
  • Topics: 1
Yes you can check the resistance of the coil & the plug caps with a multimeter, it did think at one time the ics was faulty but it was not the case, also check the pipes from the ics for leaks, can’t remember of the top of my head what the readings of the coils & plug caps should be but Marcel will probably know
Found the reference values for ignition coil resistance in the manual, here is the picture if anyone needs it in the future.
You can find it on the following link. https://ibb.co/QMgXn3W
