Jo
  • Topics: 1
Knowing that particular model very well your issues sound electrical to me, there are a sets of connectors under the tank on the left hand side fixed to the frame unplug & clean them they are particularly bad for grime, the idle circuit runs through one of them, also check those plug caps very prone to failure
Hey Simon, thank you very much for the reply!
Have you had an issue with the ISCV as well? I will most definitely check the wiring loom on the frame and find the adequate wiring for the ISCV, and also clean the contacts with contact spray. Is there a way to test the plug caps?
Thanks!
