Measure the hole of the exhaust inside  (the circle inside the exhaust exit port is 19cm for example)
Go on ebay or amazon to find 18.5cm OD baffle  (0.5cm is less on the baffle so it slots in the 19cm hole)
Drill a hole thru the exhaust TIP under it and THROUGH to the baffle.
Then use bolt and nut to lock it
