Nov 2, 2024 at 9:29 AM
#15421
I’ve used a timing light to check the plug lead on each cylinder number 2 lights it erratically where as number 1 cylinder blinks the cylinder beautifully
I have yet to do a compression test as I don’t have a tester at hand but seeing how I still have erratic on number 2 I need to look into this more can someone tell me tell me where to start the test process from to decipher where this erratic spark is coming from will write compression values when I get the tester
Dry & wet test values
