Chopper_Whitewolf
šŸ‘¤ Member
šŸ–Š Topic Author
  • Topics: 12
Fair enough. But have you solved the original issue with stalling at lights? Still hoping for some advice on the stalling at lights issue. I have added some Liqui Moly Carb and valve cleaner (as mine is not an EFI). I added that, filled the tank with E5 and took it for a ride before taking the exhaust off, but there was no improvement after 20 miles. Perhaps I should have mentioned that I bought my bike with an aftermarket exhaust fitted, but the original exhaust came with the bike. I asked a chap at the local Triumph dealer if an aftermarket exhaust could affect smooth running and he said it might, so I thought I’d return the factory exhaust to the bike. On removing the aftermarket one I found it had a great big crack at one of the joints (hidden from view) and the front cylinder fixing was loose because the gasket was missing. When a new gasket arrives I will be able to see if the factory exhaust improves it at all.
Does your carby GV have a manual choke?
--==I have come to comfort the disturbed and to disturb the comfortable==--
