Oct 31, 2024 at 10:50 PM
#15405
GV250 isnt compatible.
GV650 Non-classic DELPHI should work OK, but i believe the reason for 2 different part numbers is likely due slight changes to both bikes but the principle really is that both engines are 650 and they both use Delphi Sensors. It should work, otherwise expect one or 2 sensors being changed out to satisfy the non-classic 650 GV ECU
It should be fine! – as long as it says DELPHI (Aliexpress versions are not usually OEM & don’t say DELPHI in big letters on the black plastic body) and it also says “GV650” on the white sticker.
