Oh my gosh…it could blow up for real??
I wouldn’t panic, but yes bikes can blow up  (any motorcycle)  ,  ebikes blow up everyday because chinese keep using crap batteries  (just search ebike fires)
On to Hyosung now ,   it’s just that the fuel tank has a sensor inside has a plug being the same as the starter motor solenoid, so its a case of being careful with which plug is which before pressing “start”  (it sends power down there to trigger it)
You got this!
If in doubt , drain the old fuel from tank and clean it out , all that old rust might be collected on the fuel pump, so it is important to double check the fuel pump is OK   (or the bike refuses to start as pump is clogged with debris or just jammed) – Fortunately, there is replacement parts at reach on eBay USA , just make sure its new parts first.
