Sadly , you will have to get the flywheel off , because the chain may end up hooking on to 8 teeth and 2 are missing! – you will end up stripping the crank teeth as soon as compression hits!
So it is safer to get the rotor off.   Same with the clutch side!
To keep cam chains from falling, have a bungee cord pull the chain and hook the other end of bungee to ceiling of your garage
