Oct 10, 2024 at 6:49 PM
#15144
Burning Oil = Piston Rings . Scored Barrels , or Valve SEATS dripping oil in to piston chambers (hence probably sooty plugs) or simply rings on the way out with the barrel.
125 psi = You’re literally at the limit as to what hyosung considers a time to rebuild engine. Generally 150-175 psi is expected.
