Go on the headlight unit,  there is 3 screws holding the glass on the side.  Unscrew them and take the headlight glass off.
Then disconnect the wires behind the headlight glass.
Get a 14mm socket tool , and go under the fork lower tree where the headlight holder is mounted to, unscrew it.  This removes the whole headlight assembly
Reverse this to fit everything back.
Next……The plastic panel that’s under the tank left side HUGGING the frame steering head, remove it.  Disconnect the blue dash plug.
Next…. Go under the steering top yoke -> Unscrew the ignition assembly.
Next…. Unscrew the 2 bolts holding the dash unit.
Now you have a dash unit on the table ? –> The “little lights” for LEFT turn signal , hi beam, neutral, etc”  have their own screw under the dash unit.
Remove one or 2 screws under there, now you can change the bulb.
Regards
