Put the carb on the table , make sure the floats face the sky.
It should be 7mm resting and about 12-17mm lifted up by your hand (gently)
Resting must be exactly 7mm or about 7.5mm max  (6mm isn’t good or neither is 8mm) must be in the 7mm range.
Hate to say it, see the “permanent jet” that’s next to the mains & pilots = That perma-jet is for Starting the bike,  use compressed air and carb cleaner until you hear it “HISS” on the other side deep in the carb bowls, this will help clear it up.
Then take both pilot jets in your hand , face the sky , see if light shines through both jets “equally” or clean the pilot jets again.
Let us know if that helps!
