Sep 19, 2024 at 7:30 AM
#14881
Now this is the underside of the fuel tank you got the two which are obviously fuel lines I just don’t know which goes to which and then as for the red that actually seemed to be a place for a third hose???? I haven’t a clue and don’t plan on trying to start it until I do.Quote
G’day Hannah pool. Under Tank connections:
PINK is a 6mm Fuel Line on my GT250R. Fuel runs OUT from the tanks petcock there & connects to the FUEL-FILTER & then connects to the VACCUM PUMP.
Note: Vacuum PUMP has an ARROW-IN, an ARROW-OUT & a LETTER P stamped on the front of the pump . The arrows are located where the fuel lines connect to it.
Arrow-IN is FUEL-INTO-PUMP (from Fuel-Filter & Tank)
Arrow-OUT is FUEL-INTO-CARBURETOR
Letter-P is for VACCUM HOSE (from INTAKE MANIFOLD at CYLINDER-1 or FRONT CYLINDER)
LIGHT BLUE is 5mm hose like all the VACUUM LINES.
RED is idk. Looks like a home-made drain-plug but i don’t know the GV650’s.
I’d glue that screw with a bit of selleys all clear, so it doesn’t vibrate out, then fix it more seriously after a few rides.
I’d also start the bike up, if all the FLUIDS are ok. arm it up, get it lubed, stop if you hear any funny noises or leaks.
Keep some water nearby when you start it up – if it leaks fuel onto a hot exhaust it may ignite but i doubt it. Will probably just evaporate.
Flick the OFF SWITCH or turn the KEY OFF & pour water or sand on the fire. Fire Extinguishers also work.
It won’t catch on fire but it can’t hurt to have water in a bucket nearby to wash-off drips.
Hyosung GV650 Tank Parts
-----LaserBeam---->
