That would be the fuel pump,  sometimes the “strainer” is too clogged or  the pump itself needs replacing  (prefer to replace the entire fuel assembly)
Also while at it,  pour some injector cleaner in to the tank that can be mixed with fuel and use  E5 fuel as Hyosungs don’t do well long term with E10 fuel   (I am not sure what E5 means in AU ,  but here in UK E5 means 5% ethanol mix , premium grade fuel)  Even modern cars do well in E5  even if they were designed for E10 from the get go.
You may find that at odd times,  the “red FI” light will come up = it means what i described above.
If its a carb model bike = carbs and cracked intake pipes will be your first area of investigation.
Carb or EFi = Do keep in mind for their intake pipes may have “O-Rings” that have gone heat cracked, rotted due to old age since its the O-rings that seal the intake pipes to the engine cylinder heads.
