Julian
  • Topics: 4
Finally I can upload a photo demonstrating what I meant at the beginning of the post. You can clearly see where the bottom coil had been rubbing on the swing arm. I’ve since resolved the issue by subtly grinding a flat spot in the bottom coil to give adequate clearance. Its only a tiny bit but its enough without compromising the integrity of anything. All is good now with all of the linkages etc cleaned, regreased and reinstalled.
