You may just have air in the rear brake hoses that go to the “middle cbs box” that links both front and rear brakes.  You may have to bleed the whole system
OR , pump the rear brake only with a bleed kit from amazon until the air comes out. then close the bleed nipples,   pump the brakes a few times until you see pistons move on the rear one ,
If pistons move half way out, push them back in by hand, you will hear a “hiss” (faint hiss) possibly inside the master cylinder confirming air has been exhausted back  (reverse bleeding if you will!
Hope this makes sense
