Jun 28, 2024 at 3:05 PM
#13894
Light Green = RIght Turn Signal Solid Black = left turn signal , Yellow with Black Stripe (possibly RPM or Fuel Level, confirm your fuel sensor is same wire colour first!) , black with white stripe = Ground / Negative 12-V , Orange = Live power to dash and lights , Brown = Temp Sensor (650cc only) , Solid Yellow = Possibly lights (High Beam switch is activated by you or FLASH BUTTON) , Blue = Unsure yet , need to read again It has been a long time since i fixed wiring plugs under the dashboard, i usually fix the “Blue Side” due to water rust etc or previous owner neglects I will try to find an old cable for the all black dash and send photo (maybe Sunday or next week)
Is it the same for gt650r carbureted?
