Hey Steve,
Clutch Switch will cut sparks off anytime if it plays up, I’ve experienced this myself more than once on my GTR bikes , so much so , that even today we have had 2 orders in wales & dorset for clutch switches to be sent for GTR bikes.
It would be wise to replace it and get 2 of them (1 for spare) , if your local dealer can’t help , just email us.
Keep in mind, ST7s have longer bars than GTs and GTR’s , so don’t try to use their switches as it simply will be 50% too short!  – Some terminals may change too!
I would not recommend bypassing it,  as fake neutrals “can” happen , so you want to guarantee yourself the clutch is squeezed in before starting.
Also it is very important the side stand switch is Bypassed! (the most annoying object on the bike!) ,  bridge the wires , and tape it very hard so there is no chance of water invasion , lest it rots the wire and you’re back to square one.
Regulator = I pray the regulator is actually doing 13.5 during idle  and 14.5v during 5k revs  , otherwise , time to upgrade to shingdens!  (Like this one) , the stator too.
Carb bikes can get away with a poorly reg / stator for a short while, but EFI bikes are power thirsty  (with zillion sensors all over the place with a fuel pump that draws a lot of amps!) , you want to make sure the charge system is future proofed.  Less costly than replacing a delicate fried ECU and ST7 ECU’s are too difficult to buy.
