Bertie
  • Topics: 1
Hi Marcel, thank you for your reply.
I have read the forum thoroughly before ask the question and went through all your suggestions. Compression test is 150psi on both cylinders, I have bypassed the clutch but not the stand, I’ll be trying that tonight. Neutral green light on no fi codes. Fuel pump is priming when turning the key, and I can hear it working during crank. Bright blue spark at both coils. Stop button does is job CHE code when in off position and try cracking..
Fuel pump strainer clean, although when I got the bike the fuel pump was cactus and not having a replacement for it, I have open the old one, she wasn’t turning at all, I have pulled it apart and free it. She works all right but I’m wondering if she doesn’t deliver the right fuel pressure hence why the injectors won’t open. Do you think it can be the case? I’ll be sourcing a new one anyway, I was just keen to start the bike.
