Jun 15, 2024 at 7:16 AM
#13759
No oil filter ? ~That’s crazy! I mean the oil filter is so common , a lot of Suzukis use it!
FORM A M6 washers will “just about” fit inside the filter cover but washers are generally not needed.
Yeah i got a fright & felt guilty for redlining the bike. Bought SUZUKI Oil Filters but got 4 of the wrong ones, (from a DDR200 i think; were too LONG). What Suzi Oil Filter should i buy? FormA washers-cheers. (Using WASHERS under BOLT-HEAD as new bolts were 25mm long & bolt i REMOVED was 23mm. Washer is to take up space but also so bolt-head doesn’t scratch the oil filter cover).
Bike ran rough when i put new oil filter in, but 2 days later it’s smooth. Changes gear very well; the new oil is superb.
A bit of soot & smoke especially when cold – i want to show you the SPARK PLUGS to see what you think of them. I think it’s not burning fuel efficiently & there’s some fuel spray in the airbox above Carby 1.
-----LaserBeam---->
