Jun 8, 2024 at 9:58 AM
#13711
Thank you Marcel, a mini-dremel is perfect. I’m just about to hit the nut with a cold chisel to split the top, then tap 1 side of the nut until it breaks off. I hope the BOLT is not spinning. I dont think it is, as i cant pull it out. The thread size of the nut is super helpful, thank you, Marcel. 8.8mm thread dome nut. It’s a 10mm socket to get it off i think.
-----LaserBeam---->
