Jun 6, 2024 at 10:15 PM
#13687
All other service-points checked, new DID Vx3-chain & JT sprockets, new Metzler tyres, valve-clearance, compression, oilchange on engine & forks, EBC brakes all-over, new plug-caps & plugs, K&N filter, added a headlight relay just behind the lamp (less current/volt-loss thru switch-gear), +added a light on dash for sidestand-warning.
I did f’*ck up storing the tank….and broke the outlet. Not fun…but…new pump-assy’ is on the way. Hope there will be some summer left when all is in place….
