You might have to use a mini dremel steel disc and cut the mushroom top of the nut off, then slice it down,
Replace with 8.8 Stainless Acorn / Dome Nut of the same type.  Don’t use open nuts as the water/weather may try to corrode the threads.
Let us know if that worked out!
