Some ECU’s might moan , as the fresh air pumped from the airbox might affect the 02 sensor readings back to the ECU.  So i would caution this.
With that being said, I did have a customer 2011 Delphi bike with 2x 02 sensors  (i know 2011 and a delphi?) the engine had no AIS system whatsoever not even a plug for it, it was as if Korea saw no need for this particular bike not to have it   , then i had a 2008 Sentec ECU bike  that had 1 AIS system feeding the rear exhaust where the lambda sensor was.
