John
  • Topics: 10
Hi again I have just checked the fuel pump again and when you turn it over the petrol is barely coming thru  but if I put a bit of petrol in the carborator thu where the air filter  is it starts up straight away  so iam not sure what is going on even if I feed the carb directly bypassing the pump it still won’t start iam starting to wonder if it’s the carborator but the fuel bowl seem full so iam stamped
