The power cut-off issue, my bike has, is not as bad as it was. The coils, leads & caps are new; they problem was there before.
I read that the CDI unit has some sort of cut-off that causes this problem. It’s the result of some emission laws, they said.
I can’t verify if they are right. Apparently you cut one of the wires to the CDI unit & it MAY make the problem go away.
My green wire to my CDI was already cut & they didn’t leave any wire for me to reconnect it for test purposes.
When i put a new CDI unit onthe bike i still have no green wire connected to it. They say cutting it was meant to fix this cut-out sceanrio but it hasn’t.
I got the GT250R to 10,000RPM today in a few gears but i should really fix her before revving her too much. Big service is due.
-----LaserBeam---->
