May 9, 2024 at 5:28 PM
#13322
77 mph was the top speed of the 125cc engine (under the same road conditions, wind, etc…).
I will try to remove the spark plugs to upload a photo. Also, I will make a video of the idle. If I give it full throttle and release in neutral, the RPM hangs above idle and then “stabilizes”. If I give it a little throttle and release, the RPM drops below idle and then “stabilizes”.
What kind of signal does the dashboard receive? Can I replicate that with an Arduino or something similar to test the dashboard?
