Alex
  • Topics: 5
So after 5 days of owning it, It’s seems to be working fine when warm. I don’t have enough money right now to buy all the filters and compression check tool, I will get paid on Friday and order all of the filters and will get to the carbs to see what’s going on.
so main problems right now is. 5 am in the morning about 5-8 degrees, it’s quite hard to start up, but with choke on and almost full throttle it starts.
rear cylinder seems to be always more colder than front one and when engine is cold I can clearly feel that one cylinder doesn’t fires up until 4k rpm
i use it daily to get to work and back, when I start it up at 2:30 about 13 degrees outside it’s start ups fine without choke but giving it a throttle
there is actually no smoke from exhaust so it’s might been just steam
Oil level stays in same position so it’s not going anywhere , so I don’t really think there is problems inside engine but I will anyways check compression later and will update you
and also just as temporary I put inside that wynns thing in fuel tank to see if it will change anything before I will get everything
and last bit! I’m not sure if it’s a really something but it smells quite more than should be with petrol from exhaust but it’s black widow exhaust without baffle fitted on
im not English (sorry for mistakes if there’s any :))
