Welcome!  – Hope you will take a picture journal thread in the forum so we can follow you exploits all the way to the track 😉 Be nice to see that!
Let’s start with the exhaust…..
– Do you have a budget ?  There is a UK company that makes stainless exhausts for us here in UK but it is possible they will ship to AU as they do have an ebay shop themselves by the name of BLACK WIDOW EXHAUSTS
Or
– Do you know someone locally who is able to “cut” the middle cat box of your stock pipes ===> then replace the middle with a straight pipe , then go grazy with VHT paint , nature forbid it rains and the oem pipes start rusting due to unpainted surface on it.
For muffler , }
– Have you learned any regulations in your State about how loud the bike should be ? any meters they use to test bike noise levels. ?
There may be a chance that they want a “full size” muffler  (similar to the OEM version) but aftermarket ones will be loads lighter.
If you keep the stock exhaust pipes ====> Cut the 4 bolt flange off ==> The find any “51mm slip-on” exhaust can/muffler that will comply with your local track noise levels ?
