Mar 26, 2024 at 4:37 AM
#12725
Hi I think that the the first step is to ensure that You have a proper voltage try with the regulator/rectifier first al cleaning and servicing the carbs it Will take an hour or less depending of what you find also, you can test You regulator with a multimeter and descart it here is a video to test it
And just un case the regulator pinout
You can Even adapt another three phasic regulator just be sure it’s treephasic
