Mar 24, 2024 at 8:24 PM
#12717
ooooo!
Okay , go on Amazon and try to find “RUBBER FUEL RESISTANT GASKET” (must be fuel safe rubber sheet that is about same thickness as your old gasket)
Drain your fuel tank safely and remove the sensor.
Cut the new gasket using your old gasket as a template. , fit everything back together.
Add fuel and check for leaks!
