Thanks for the reply Marcel, I have had the carby’s apart but did not have a magnifier to see the numbers on the jets, I think your on the right track it may have been jetted for the stainless exhaust. I know I will have to remove and check, post the numbers and see why it bogs acceleration under load.
I bought a genuine air filter and installed as there was none, I have today seated the airbox properly onto the carby’s first then the intake to the motor. I needed to have some help doing it as yes its tricky to do properly.
The mod you suggested was done already, I thought of reversing it or going the middle 2nd notch on the slide needle top.
Have not ridden today and am having to deal with other things for a week or two, so have to put this project on hold.
