1 – Is everyone facing the back tire’s protector wearing off more on one side rather than on both sides at the same time?
You would be correct to say that the heavier side of the bike , means it is also easier to lean to it around the turns / bendy roads
So check that the wheel is also “100% straight” , as it if is like this  /…../   instead of  |…..|   , it could also cause more wear on the belts too.
2 – I’ve made a lot of upgrades to my GV in different ways and have a couple of ideas. What I’m planning to add is an oil radiator (yes, you heard it right). Now I’m gathering the info about the motor itself and can’t find what’s the hole under “????” mark. Can someone help? At least who had an experience of tearing this motor down? Cause I never got that far.
I believe that is just for the oil to circulate back in to the engine since the plug is there to stop oil shooting out   (until there is gauge to check circulating oil pressure.)
3 – What do you do with the stock rear and front pulleys? Riding on a stock? Or got some upgrades too? Cause I’ve got an ST7 front pulley on my 2007 GV (no longer sold anywhere in the world, unless from hands). And the neck of it is twice as big as the 2007’s one. My rear pulley is now being modified with a hardened metal (planning to use a duraluminium plate instead of weak OEM silumin). Will share the results later. Whoever is riding a bike (GV650) and if it’s older than 2013, keep in mind, TIGHT your front pulley nut every season (at least twice to 3 times with 140 torque) Otherwise here’s the result and it’s not the worst one, even.
Have you considered switching to  X-Ring chain kits ?  – I have been thinbking of doing it on the shop, as some of my GV customers seem to prefer chain methods than dealing with pulleys and belts all the time …. but alas, the belts are smoooooooooth! (& more classic)
